Originally Posted by
kirstysdad
I am tending towards the PU3/SL150 except my homemade acrylic arm board might be a limiting factor. I suspect my measurements are incorrect.
Can anyone provide me with a template as I fear my measurements are bollox!
That said, the SME/LP12 is a classic and sound lovely even with a DIY acrylic board it takes me back to 1983...
I am using a cheapy Goldring E3 that has, TBH, exceeded my expectation...
Sandy, I would completely ignore any comments regarding your setup. At the end of the day, it's what makes you happy and if having 2 setups works for you, then so be it! It dosen't matter how you reach sonic nirvana so long as you enjoy yourself getting there.
