Page 5 of 13 FirstFirst ... 34567 ... LastLast
Results 41 to 50 of 123
Thread: Energy usage- valve amp!
  1. #41
    Probably something like 10p/hour now.
    Certainly more than the EWA M50 power amp, less than a big Pass class A.
    Whilst it's obviously not the cheapest amp to run, it puts heat in the room, and sounds great.
    Given the hours you run it, it can't be the cause of your massive bills, surely.
  2. #42
    I'm Dennis.
    Maximum theoretical efficiency of class A is 45%.
  3. #43
    I'm Andy.
    If your Prima Luna is 300 watt, it's on 13 hours a week, assuming electricity costs 35p per kWh then that's about £1.37 a week plus your standing charge, plus all the other bits of kit you have turned on.
    I am all electric including an ASHP in a detached 4 bed bungalow in an exposed location with twin valve monoblocks, I burn 7000kWh annually so that's 7000x0.35=£2450 plus a couple of hundred standing charge. So my total is £2650/12=£221 per month
    Hope that helps
    Analogue
    401 / PU7 / AT33ev
    Digital
    Vortexbox,
    Caiman Seg & Dorado
    Cambridge CXC
    Amps
    Tron Seven Linestage
    Speakers
    Tannoy GRF Memory.
    Tannoy ST100.
  4. #44
    Quick n easy check for you. Check your bill for the cost of a Kw/h, probably around 40p now.
    Tour your house and turn everything practical off at the wall (not the fridge freezer, I'd suggest), lights off, everything you can find off.
    Take a meter read. Let's say the read is 10000.
    Take another read after an hour without turning anything electric on (no cheeky cups of tea). If it's now 10002, you've used 2 Kwh's. At 40p per K/wh that's 80p.
    Now turn on and give your hifi a blast for an hour. If the meter's advanced from 10002 to 10007 that's 5 Kwh's at 40p each = £2.
    Two of those Kwh's are from the fridge (as per the first test) so your hifi's cost £1.20 for the hour.
    For reference, one of the biggest culprits is an electric water/immersion heater if you have one. They're the devil. Do NOT leave them on for any longer than strictly necessary.
    Mark Levinson 390 CD & Audiolab 6000 CD Transport / Soncoz SGD1 DAC / Croft 25RS Preamp / Croft 7R mono Amps / Neat Ultimatum XLS Speakers
  5. #45
    I'm Lloyd.
    Quote Originally Posted by Stranraer View Post
    Brilliantly simple way to work out and see the costs thanks for this idea
    A widower finding solace in music
  6. #46
    I'm Shaun.
    My power amp is Class A apparently and runs bloody hot so I have rigged up a USB fan above it to help to circulate the heat as it is sat on the bottom shelf of a heavy pine table. After an hour of use the room is notably warmer when we walk in. I need to calculate whether the amp is cheaper at heating the room than the radiators.
  7. #47
    I'm Shaun.
  8. #48
    Quote Originally Posted by Enossification View Post
    the central heating will be more cost effective i guess but with the amp your getting 2 for one..
    OPPO BDP-103D - PANASONIC UB450 - PANASONIC 4K ULTRA HD TV - AVANTREE LR BLUETOOTH - NURAPHONE', BOSE, CAMBRIDGE, BOWER & WILKINS, DEVIALET & SONY HEADPHONES - 2*ZBOOK'- ROON, QOBUZ, PLEX, JRIVER - MULTI HDD'S -
    **I’ve studied deeply in the philosophies and religions, but cheerfulness kept breaking through**
    **Hate makes you impotent, Love makes you crazy. Somewhere in the middle you can survive.**
    “Nothing discloses real character like the use of power. It is easy for the weak to be gentle. Most people can bear adversity. But if you wish to know what a man really is, give him power. This is the supreme test. It is the glory of Lincoln that, having almost absolute power, he never abused it, except on the side of mercy.”
    There's nothing remarkable about it. All one has to do is hit the right keys at the right time and the instrument plays itself. -- Johann Sebastian Bach.
    I'm Shaun.
  10. #50
    I'm Shaun.
    OK so my observation of our smart meter display was as good as my knowledge of electronics. My amp consumes 720 Watts when switched on giving a cost of around 27 pence per hour. Even on standby my amp consumes 70 Watts or so. What a bloody time to buy the amp you always dreamed of owning.
