Hello all, as you can see from my signature I am using a valve preamp built from a kit and although it sounds good I am hoping for an improvement on SQ and a remote for volume too.
I was thinking that spending on a better preamp will improve my system. Two things arise from this thought though; 1 - what level would you recommend spending at to maybe push the boundaries of the Cambridge with a future upgrade later
2- Spend a little more and get a pre and power amp (or integrated) from the same manufacturer and stop upgrading the amps in the future.
As a side note, I bought the DAC and it improved the sound from the computer a lot as I had hoped and also added bass to the Cd player.
I don't know whether to go with a better CD player in the future or rip them, was going to let the Linn die and then decide. Although it will probably depend how long it lives for
As I am in NZ I have a little more limited choice of equipment as compared to the UK, so this might be a factor too
