[FS] Parasound Halo A21 power amp.
Sadly having to sell this. I only bought it in October, but I need to simplify my system even more, so my wife can use it. So now it's down to an integrated Accuphase E-207.
This is the second one I have bought, I just wish I could afford to keep it. It will drive practically anything, is silent, and has delicacy as well as power.
I'm asking £1500 for it, with original packing, and I can deliver it within a reasonable* distance of Plymouth, or postage at cost.
About 6 years old now, I believe, according to mickhick1, from whom I bought it. In very good condition, of course.
Images below copied from Mick's original advert, as my phone camera isn't nearly as good!
Details:
Continuous power output:
250 watts RMS x 2, 20 Hz - 20 kHz, 8 Ω, all channels driven
400 watts RMS x 2, 20 Hz - 20 kHz, 4 Ω, all channels driven
750 watts RMS x 1, 20 Hz - 20 kHz, 8 Ω
Current capacity:
60 amperes peak per channel
Power bandwidth:
5 Hz - 100 kHz, +0/-3 dB at 1 watt
Total harmonic distortion:
< 0.2 % at full power
IM distortion: balanced 16 V rms
< 0.04 %
Slew rate:
> 130 V/µsecond
Dynamic headroom:
> 1.5 dB
Interchannel crosstalk:
> 80 dB at 1 kHz;
> 63 dB at 20 kHz
Input sensitivity:
1 V for 28.28 V, THX Reference Level
Input impedance:
33 k Ω unbalanced; 66 k Ω balanced
S/N ratio:
112 dB, input shorted, IHF A-weighted
Damping factor:
> 1100 at 20 Hz
Dimensions:
17-1/2" w x 7-5/8" h x 20" d, 7" h without feet
Net weight: 60 lb.
https://www.parasound.com/pdfs/A21Manual.pdf
Collection from Plymouth, could deliver. Or postage at cost.
£1500.
*Definition of reasonable distance? Flexible.
ABD.
ABD.
- You may not post replies
- You may not edit your posts
Forum Rules
