Results 21 to 30 of 36
Thread: IMF tls 80 problem
  1. #21
    I'm mike.
    Maybe younger eyes can make out the type better than mine.
    Sent from my SM-A217F using Tapatalk
  2. #22
    Quote Originally Posted by 09mike69 View Post
    I'd like to find out why it won't power the tweet and super tweeter first.
    Assuming connections between crossover and drivers are sound then it has to mean that some part(s) of the crossovers are shagged. You know the drivers are okay so what else can it be? There isn't anything else.
  3. #23
    I'm mike.
    There is the unknown cap glued to the baffle. And the fact its the same on both speakers.
    I agree with the shagged cap approach but because they have been messed with I'm concerned what may have caused the problem.
    Why the inline cap on the baffle, spoke to falcon acoustics and they had not seen or heard of it on these speakers.
    And no caps on the speaker terminal or tone switch.
  4. #24
    caps would i guess be put there either to protect tweeter or to limit its response(or both)
    Looks like a resistor to me.
  6. #26
    That screw is where the knob used to be so it's be removed by the modders. Also I don't think they are TLS80s from the label they are probably the earlier Transmission Line Loudspeaker I think they were called.
  7. #27
    I'm mike.
    My thought too, removed the tone switch and put an inline resistor on the tweeter,
    Still can't figure out why the tweeters won't work in situ.
    Cheers
    Mike
  8. #28
    I'm mike.
    Ok so I removed the resistor and both tweets are now producing sound.
    Sounded a tad low but I'll get a better idea when I reconnect the speaker units and have a listen.
    Thanks for all replies, and I'll post back when I've had chance to put them back together and had a listen.
    Cheers
    Mike.
  9. #29
    What's the value of the resistor? It's normally about 1-2 ohm to reduce the treble level (in series). Much higher would explain the issue. Although why anyone would want to add it in the first place is a mystery.
  10. #30
    I'm mike.
    I don't know I'd have to measure it, there's no value marked on it.
    I won't replace it.
    Hopefully get time today to get them up and running.
