Super shiny final/fine polishing done.
This bespoke Audio Technica 1503 tonearm armlift holder/mount is ready.
Made from solid stainless steel 6mm thick plate.
Double grubscrews on both the armpillar and Jelco arm lift.
An elegant solution to easy and safe cueing.
Using a Jelco armlift and Audio Technical arm clip.
It cleverly allows the use of the anti-skate mechanism too
Pics show finished article back to raw 6mm stainless steel plate
Test fitting before polishing
Spinning up for machining the mounting holes
Raw 6mm SS plate, rough shaped
