Power amp recommendations for Rogers pro9tls
Would like to try something different to run the Rogers. Currently using my 211 valve based power amp with a Firebottle kin pre amp. Fancy trying a different power amp something maybe like a quad 606/707/909 or anything with a bit of oomph. Would need to work well with the firebottle. Room is 22’x 14’6. Having to go to 2/3 o’clock on the volume when playing at party levels🥳 Not sure this is a problem as it sounds fine just worried l may be causing damage .
Any suggestions?
Pete.
Main amp is an Electrocompaniat eci2 Sony qs930 cd, Sony tuner,Stan dac,modified x10d with little pinkie se and of course Quad esl57s fully serviced with much better legs and widgets. Sometimes swap to my kef reference 3s or Rogers pro9 Tls.
