Results 1 to 6 of 6
Thread: What is this inductor value
    Default What is this inductor value
    This may be asking the impossible, but you don't know till you try
    I have a pair of these inductors taken from a vintage pair of Rogers speakers. I have no way to measure their values - all I have is that the resistance is about 0.5 ohms, the copper winding about 1.4mm and the weight of each is 450g. The central square former is plastic/ Bakelite.
    Would anybody like to hazard a guess at the value.
    If its totally impossible to guess, please say so. This will stop me waiting on answers.
    Thanks
    Chris
    Source
    SW1X USB II
    SW1X DAC III Special
    Audiolab 6000 CDT transport
    Amps
    Speakers
    BK Electronics XLS400FF Sub.
    Cabling
    Headphones
    Could make a stab at it if the number of turns were known.
    Or 2 seconds to read the value on my LCR meter.
    Or tell us which model they're from and we might be able to work it out from available schematics.
    Sent from my BKL-L09 using Tapatalk
    Alan
    I didn't know there was a simple meter that could make this measurement. Everything I read suggested I needed an oscilloscope Found LCR meter at less than £25 so its on my borthday list.
    Lawrence
    Inspired by your post I went out to the shed to see if I could make out the model number on the old stripped Radford cabinets I stored there. And then a magic moment - when I found the crossover circuit diagram on a metal plate. The main driver was a KEF B139 with inductor of value 2mH.
    So, mystery solved. Thanks for your help.
    Source
    SW1X USB II
    Amps
    Speakers
    Cabling
    Headphones
    Great news. I wonder if that's the same inductor value as in the B139 filter in the Kef Concerto crossover you can get from Falcon.
    It seems the Concerto also had a 2mH inductor as I suspected. Interestingly there was a later concerto crossover that used a 4mH inductor.
    https://www.falconacoustics.co.uk/ke...r-upgrade.html
