I like Barry's advice, gonna leave the stock arm on. I'm only interested in MM carts now as the styli can be changed, so much more economical. So, anyone got a nag mp200 body lying around? Failing that I'll try a Goldring I think.
Arm is already decent enough, I'd change the headshell though
I ran mine with a Misson 774 arm after the stock arm mind you, and eventually a Fidelity Research FR64fx.
I was able to upgrade in stages with less cash at the time than forking out for a better TT in one go.
But to be honest, I wouldn't go that route again.
IMO the stock arm is the only weak point on the deck, it's okay - until you hear it with a better arm.
Most of the other mods are either marginal or pointless.
I'd put the better arm on it and sort out a compatible cartridge/headshell.
Also replace stock rubber mat with a Funk Firm Achromat, that's worth doing.
Yes it is good enough but a better arm does make a big improvement in sound quality. I was sceptical too until it was demonstrated to me.
It's a question of economics. It will not be cheap to fit an alternative tonearm that would substantially upgrade the sound.
It may take a better arm than the Jelco 750 to make the expense worthwhile.
Misson 774 arm would be my choice, not the LC one.
An armboard from Magna Audio too.
+1 for the original Mission 774.
Amazingly versatile arm and works superbly on the 1210. I have previously used Jelco 750 and TK850s and prefer the Mission. I've used it with MM's including Decca Supergold and high and low output MC's with great results. The DL-304 (and DL-160) work particularly well.
Sent from my Pixel 6 Pro using Tapatalk
Always a little further
