Results 1 to 10 of 20
Thread: Horn Pondering.
    Default Horn Pondering.
    Just mulling ideas over.
    Has anybody got an idea if an eighth wavelength constant width back loaded folded horn speaker might work? I've built successful 1/4 wave units in the past.
    I'm not referring to the Troels Gravesen types, which have a restricted exit and appear to work as some sort of acoustic column.
    I know 1/8 wavelength transmission lines can work well enough.
    I'm Shane.
    Hope you are well, Geoff.
    What amp are you currently using?
    S.
    Shane Lonergan.
    Quote Originally Posted by southall-1998_mk2 View Post
    S.
    Hi Shane, I'm fine mate (relatively ).
    I've got a variety of amps, but keep going back to the NAD 3130. Cheap but amazingly good.
    I'm Shane.
    NAD has produced some great gear. Have fun!
    S.
    Shane Lonergan.
    With your B&W DM2a's
    I'm not aware of the advantages of a quarter wave rear horn loading, is it a "thing"?
    Back loaded quarter wave horns have been in use for a lifetime, as per Lowther. Bass dynamics with a BLH can be spectacular, if limited in depth.
    I did ask about eighth wavelength. I think there may be something to it, the energy at the horn mouth is halved for each halving of line length, but as with eighth wavelength transmission lines, there is still a proportion of positive pulse.
    Incidentally, IMF and PMC have made truncated transmission line speakers which appear to have line lengths as short as 1/16th wavelength.
    Those will be the bookshelf ones? I guess any length line may help to reduce potential phase issues of a simple port, quarter wave is just the ideal one.
    I suppose a half wavelength transmission line would be the ideal, but it would be enormous and would need a lot of internal damping to avoid a big bass hump.
    (I'm just visualising the size it might need to be for 15 inch Tannoys )
    I'm not keen on any type of horn-loading.
    Not sure why transmission lines are being brought up, since they're not the same thing? Plus transmission line loudspeakers are rarely true transmission lines.
    This is one of those 'If you want to go to Dublin I wouldn't start from here' situations
    I've always thought best bass loading was a good big driver in a large sealed cab. Not optimal as nothing is but I reckon it is the best compromise.
    I have owned Lowther Acoustas, Lowther Medallions and Hedlund horns, do these qualify in what you are looking at. I have also had at home for evaluation Impulse H6s and Impulse H2s.
    I think the drivers are at least as important as the cabinets.
    Source
    SW1X USB II
    SW1X DAC III Special
    Audiolab 6000 CDT transport
    Amps
    Speakers
    BK Electronics XLS400FF Sub.
    Cabling
    Headphones
