Results 1 to 4 of 4
Thread: FS Teddy Pardo RCA-DIN 5-pin audio cable
    I'm Gren.
    Default FS Teddy Pardo RCA-DIN 5-pin audio cable
    High quality Silver/Teflon interconnect with Neutrik Profi RCA connectors. Used to connect Naim sources with 5-pin 180 degree DIN sockets to other equipment with standard RCA sockets. It can also be used to connect sources with RCA output to a Naim pre amplifier. £100 posted
    [IMG]IMG_3474 by James kirk, on Flickr[/IMG]
    System Sources: Naim cdx2-2, Sonos and AppleTV, SL1210 Mk2 the journey, so far isonoe feet and sumiko headshell, Jelco SA750D. Mike New bearing,bonded baseplate and copper armboard, now installed. Paul Hynes PSUSR7EHD-21/27, funk achromat .
    Pre-amp: Teddy Pardo PR1
    Power Teddy Pardo 2xMB100's
    Other: Focal Electra 1028be
    I'm Barrington.
    What length is the cable?
    Point of information:
    The RCA plugs look to be WBT type 0102Cu, not Neutrik 'Profi'.
    Good luck with the sale.
    I'm Gren.
    The cable is 104cm long and Barry you are correct for the RCA WBT 01-02Cu
