Good to know about the Windows 11 possibility.
Up through 2019 they had an international website with all the drivers and firmware
www.calyxaudio.com/cgi/bbs/board.php which now seems to be gone. They still have
http://www.calyx.kr/xe/notice but it seems to be missing the most recent firmware (3.3.0) for Calyx 24/192 on Windows, though they do have it for OS-X.
Here is the rub, in order to get on the current driver 1.61.0, one needs to first update the DAC’s firmware to 3.3.0, but one can’t see what firmware version exists except from the Thesycon app which is part of driver software and they don’t have the older driver software on the website any more, nor firmware 3.3.0.
So if you know the DAC is on vers 3.3.0, you can update the Windows driver to 1.61.0. If you don’t know but have the original driver on CD, you can install that first but can’t get 3.3.0 any more so can’t use 1.61.0 ! Since my DAC is on firmware 3.3.0, I can install 1.61.0 on any older windows machine. Whew, their website is a patchwork mess!
Tip: note the search icon at the bottom left of
http://www.calyx.kr/xe/notice which will help find what is and isn’t there.
Note: 1.61.0 only works reliably up through windows 8.
