Page 1 of 3 123 LastLast
Results 1 to 10 of 27
Thread: FS: Breeze Audio CM6631 USB to SPDIF convertor £40
    Default FS: Breeze Audio CM6631 USB to SPDIF convertor £40
    An oldie but a goodie. Been on my reserves bench since I bought a JKenny but time to let it go. Ideal way to keep using your favourite vintage DAC for streaming or computer digital.
    Has a proper built in LPSU none of this walwart nonsense. Missing the little optical input flap. I think it's optional to run off USB power with the switch on the back - but don't quote me on that! Sorry I don't know the exact specs but it's suited me fine with high res listening on my Pi and Zen. Just tried with my Rpi4 running Volumio and it worked a treat.
    Asking £40 collected from N London or plus delivery.
    Thought this might get some interest as it's priced at the cost of a s/h Chinese LPS with a free usb converter thrown in!
    I did look it up and it's 24/192 compatible, in fact it might go up to 32 bit but I've never tried.
    I'm Rob.
    I'd be quite interested in this but I have quite a few questions!
    I have a dac with coax in. Is it as simple as hook it up to the dac, plugg this device into my win 7 laptop and bingo? what do I actually need to do here other than tell windows where to send the sound? does it want drivers etc? will it make a sound difference out of the box? are there tweaks I should know about?
    Quote Originally Posted by Gramophonic View Post
    In theory yes but sometimes Windows requires a driver to recognise a dac or convertor. I've got a W10 laptop so why don't I try it with that and see how I get on.
    In terms of sound difference yes it should improve it but I guess it depends how you're using your laptop now?
    I'm Rob.
    If you would be able to do that without a lot of messing about I'd be really grateful!
    Sure I'll have a look now shouldn't take long
    Sorry I can't get my laptop to recognize it, shame as it's plug and play with my Innuos Zen and Raspberry Pi but I guess it's a Windows 10 driver issue.
    I'm Rob.
    ah that's a shame, thanks for trying though!
    I found W7 and W8 drivers online for the CMedia CM6631 chip but they didn't work on my laptop. Bit of a risk to assume they will work.
