Results 1 to 10 of 11
Thread: Bamboo - Suitability as a TT plinth?
    I'm Ken.
    Default Bamboo - Suitability as a TT plinth?
    I'm toying with the idea of a new Turntable project and considering what I might make a plinth from.
    Done Concrete and Birch Ply in the past, looking a bit outside the box.
    I came across the IKEA Aptitlig Butchers Block £15 each.
    45 x 36 x 3.3cm constructed of Bamboo strips.
    Glue 3 of these together and you have a 100mm thick plinth roughly the right size for a turntable.
    The weight of this triple layered block would be 9.5Kg (20.9 lbs) before any cut outs, so quite heavy.
    Bamboo is a fibrous materiel and in this laminated construction is very rigid.
    Has anyone got experience of this material as a plinth ?
    Wondering what its acoustic/damping properties might be.
    Edit:
    I came accross this by "cats squirrel" on vinylengine.com
    "I have looked at the suitability of bamboo products for use in hifi builds. The resinated bamboo, available in many forms, looks a good product, for use in plinths, supports and as seen above, loudspeaker boxes. I have measured the damping factor of resinated bamboo, and obtained a figure of about 0.2, that is over 10 times better than mdf, and even over twice as good as Torlyte, the Russ Andrews' product.
    I use a resinated bamboo chopping board under a Lenco plinth, and that is spiked to a 'Chinese Go' board, made from three layers of tiny resinated bamboo tiles. They serve their purpose well."
    Edit:
    I also found a company making Bamboo plinths for LP12's so I think I've answered my own question.
    I'm Gary.
    I use this material for shelves on my rack and think it would be perfect for a plinth. If you could cross laminate it maybe even better.
    Gary
    Quote Originally Posted by Qwin View Post
    Edit:
    Edit:
    PRE
    I'm Ken.
    Quote Originally Posted by Wakefield Turntables View Post
    I'm loheswaran.
    Artemis Labs use Bamboo inn the plinth - superb turntable btw
    I'm Ken.
    This is my on going project, using 40mm thick slabs of Bamboo Kitchen worktop.
    https://www.jkwynn.co.uk/Lenco/Lenco_Thumbs.html
    I'm loheswaran.
    Excellent work
    I'm shahrin.
    yeah excellent work Ken and nice write up.
    Thorens td124 mk2 / Bokrand AB309/ 103r
    SLAT L75 / Jelco 850S / AT VM740ML
    Marantz CD63 / Bluesound / Musical Paradise 701 II/ ESP 500Hz eXO / PL Prologue 4 and Nord 1UP amps / JK Wynn semiactive NS1000 upgrade
    /ESP 700 Hz eXO / JBL 4333 components
    I'm Ken.
    Thanks guys.
    You should do a write up on the three decks you are building Shahrin.
    I'm Bruce.
    This is a better choice than the Ikea Aptitlig which has somewhat random gaps in it's layers. Fine as a whole shelf but start cutting into it more than an inch from the edge and you may or may not get what you expect.
    Your project and writeup look great, by the way!
    Bruce
    Theories are not so much answers as questions, to be supported or undermined by experience & testing.
    Source: Audiolab 6000CDT > Calyx 24/192 DAC
    Amplification: Pass-design B1rev2 pre-amplifier > Neurochrome Modulus 686.
    Loudspeakers: Proac Response 1SC
    Cables/stands: spkr: MIT MH-750 biwire; IC: HT Truthlink; Target stands, sand-filled; Excel Cat6A 23AWG UFTP & 1attack.de Cat.7 SFTP.
    Other: Balanced AC transformer to hydra mains distr; Bass traps & Acoustic panels; Isolation: Inner tube & roller bearings; 3xZyxel ES104A switches in series w/Vreg upgrades.
