Results 21 to 30 of 32
Thread: Which DAC ?
  1. #21
    Yes thanks apart from the concerns you'll be well aware of. Gabriel has turned out to be a talented little football player
    Apologies to the OP for the thread drift!
    So it's a Bluesound Node plus a good DAC with the change from £500. Dare I suggest Topping?
  2. #22
    I'm Aris.
    Maybe I have to explain better my needs.
    I have a 1TB~ digital library (FLAC files) that I will put on my NAS, and I would like to listen to this library through my system.
    Problem: all the inputs of the Croft Micro 25R pre-amp are occupied.
    My "thinking" was: use a DAC with at least one RCA input (to free an input on the Croft pre), connecting the DAC to the NAS via Ethernet or USB, and connect the DAC (OUT RCA) to a Croft input...
    This way when I select "line 3" (for example), I will listen to the sources connected to the DAC...
    As stated..I am not an "expert"...
    Maybe as Lawrence001 suggest, a streamer is more suited for this need ?
    Edward: No, unfortunately JRiver cannot be installed on Synology NAS, but this app could https://www.synology.com/en-in/dsm/f.../audio_station , or Plex Media server.
    Thanks !
    Nottingham Analogue Dais, Ace Space 12", Decca Super Gold, Croft Micro 25R, Croft Series 7R, Harbeth SHL5+, Oppo BDP-105D, Hama DIT2010
    "Utopia is on the horizon. I move two steps closer; it move two steps further away. I walk another ten steps and the horizon runs ten steps further away. As much as I may walk, I'll never reach it. So what's the point of Utopia? The point is this: to keep walking." E.Galeano
  3. #23
    I'm Ian.
    I have a qed switch box in a cupboard some where, clicks and pops galore never worked for me, might be faulty dont know, BUT i can 200%,recomend kramer switch boxes, they cost a fortune but come upnon the bay for peanuts, well a few quid
  4. #24
    I'm Kevin.
    Only DAC I know of (I don’t know many) with an RCA input is the Benchmark DAC HGC. It comes in version 1, 2 or 3, and I think you can bypass the volume control. The DAC 3 version may be called the DAC 3L
    Kevin
  5. #25
    I'm Alastair.
    DACs with an RCA input are few and far between, if they exist at all. If your OPPO has a digital out (Coax or Optical) you could feed that into a DAC, thus freeing-up RCA inputs on your Croft. You might be able to do the same with your Hama too. Many DACs have a remote so you can switch between the outputs.
    Cheers
    Alastair
    RPI4/PI2AES running PiCorePlayer/LMS-> AQ Carbon AES -> Topping D90 DAC-> Khozomo Passive Pre-Amp -> 4x Temple Audio Monoblocks powered by 2xLiFePO batteries->Van Damme Black Bi-Wired to B&W 804 Nautilus and Sommer Carbokab 225 Interconnects
  6. #26
    The RME Pro has analogue input but XLR only so you'd have to use adaptors. It's expensive but does have a lot of bells and whistles.
    https://www.dv247.com/en_GB/GBP/RME-...90c1a6a8cbee45
  7. #27
    or there's this one a bit cheaper https://www.analogueseduction.net/da...minilpro3.html
  8. #28
    Stan Beresford made one. Think I've still got it. But he sells a multiswitch still I think.
    I'm Aris.
    I'm back..
    I found the solution....was already "there"...
    The Oppo has a "network" option as a source and I've checked if it was possible play some music from the NAS and it run without problem!
    I think I am set.
    Thanks for all the help and suggestions.
    http://download.oppodigital.com/BDP1...ish_v1.1.2.pdf
