Page 1 of 4 123 ... LastLast
Results 1 to 10 of 32
Thread: Which DAC ?
    I'm Aris.
    Default Which DAC ?
    Hello everyone,
    I would like to ask a suggestion...
    Bearing in mind that all input of my pre croft Micro 25R are used, what solution you suggest to implement a media server ?
    Slowly but steadily, I have amassed quite a big digital library and I would like to being able to listen to it through my system...
    What solution you think will work best ?
    Any recommendation ?
    I am not an expert...
    Thanks !
    Nottingham Analogue Dais, Ace Space 12", Decca Super Gold, Croft Micro 25R, Croft Series 7R, Harbeth SHL5+, Oppo BDP-105D, Hama DIT2010
    "Utopia is on the horizon. I move two steps closer; it move two steps further away. I walk another ten steps and the horizon runs ten steps further away. As much as I may walk, I'll never reach it. So what's the point of Utopia? The point is this: to keep walking." E.Galeano
    you can get an input switcher box to give you one or more additional inputs. Loads of them about starting at £15
    I'm Aris.
    Hi Macca,
    Thanks for the help.
    Any specific product recommendation ?
    Thanks
    There's usually a QED on eBay. You could rewire it internally with better cable sometime if you're able.
    Just out of interest what are all your sources?
    I'm Aris.
    Thanks Lawrence001,
    Better buy an already finished product...
    My sources are: Dias, Oppo, Hama, and a Sat decoder for Tv (Humax iCord).
    Quote Originally Posted by Gibo69 View Post
    Thanks Lawrence001,
    The QED is a finished product.
    Hi Macca,
    Thanks
    As already said QED are a safe bet.
    I'm Aris.
    Yes, but I was referring to the suggestion of "rewiring the internal cables"..
    I'm Aris.
    Found it on ebay.
    Thanks !
    None of those, they are all for connecting multiple speakers. You need an input switcher.
    here https://www.ebay.co.uk/itm/194429872...75.c101224.m-1
    Or this one is BIN https://www.ebay.co.uk/itm/304133094...0AAOSw7v1hM1u4
