Quad 303 might be OK.
I'm Graham.
Thanks for the comments on the Technics Amplifier, It states 30 Watts per channel and has speaker A and/or B outlets. I will post back results of the capacitor experiments/changes. I hope to see a bargain Amp one day to upgrade the Technics if needed.
Erm, no idea, but welcome to AoS!
Alex
Amplifier: Rega Brio R. Speakers: Spendor SP1. Cables: Various, mainly Mark Grant. Please see "about me" for the rest of my cr@p! Gallery
Something doesn't sound right about your description of the crossovers. A 2.5 or 3 way speaker can't have a single inductor as it needs multiple low pass filters.
[EDIT Sorry I should have considered the low to mid range driver could naturally roll off at the top and not need an inductor so take this bit with a pinch of salt]
It's possible there's another crossover or inductor elsewhere in the cabinet so that might explain it
However, I did a search for your crossover and found the photo attached. It claims to come from a Mercury MX2 2 way speaker, which makes more sense.
So I'm wondering if you bought these second hand and someone had a go at repairing them with the wrong crossover. This could also explain the "distant" sound you can hear.
I suppose the low pass could go to both bass drivers with an additional inductor to filter out the mid range from the .5 woofer although this is an odd arrangement.
I think the best thing you can do is post some photos here for us to help.
Good theory that Lawrence.
If we can get a copy of the proper crossover circuit a new one can be built with good components and they'll sound better than the originals
I'm Graham.
Here's a photo of the crossover. the blue caps values are 10uF ans 8.2uF the large one is 5.6uF I thought the big blue component was a capacitor but I think it is an inductance coil?
I'm Graham.
Armed with a solder sucker and my old but still working L/C meter, I have just checked out a couple of capacitors and both well withing spec, so maybe the next step is to look at an upgrade of the Technics amplifier. I am looking at several Arcams on Ebay. Would an Arcam Alpha be a move in the right direction, I have a feeling it's a trifle tpp retro? Seller majors on 'comfort and for a small space. I want to be reduced to emotional wreckage - Shostakovich !0th for instance. Comments welcome
This
https://www.emporiumhifi.com/kent-br...ntegrated-amp/
if that's too pricey look for a Denon PMA350, ideally a mark one version, should be around a ton.
I'm Graham.
I will start a new thread/continue this in a more 'proper' part of the forum. Thanks for your help(s). I am looking for Denon PMA350.
