Results 1 to 6 of 6
Thread: Novafidelity/cocktail audio
    Default Novafidelity/cocktail audio
    Hello, is anyone using any of the novafidelity/cocktail audio devices? I'm using an x40, great but quirky. I have say 10 albums by David Bowie, if i search David Bowie it might show just two albums the others coming under Bowie David, david bowie, etc, is there any way I can group them all together? Same issues with other artists, any help would be great, ta Jim
    I'm Peter.
    Hi Jim, sounds like a meta data issue and is caused by the files being named in different ways. ie some named "David Bowie" and some "Bowie David".
    I have not used the unit you are using but you may need to edit the tag files/information so that the artist name is all the same.
    Here's a link to where it is explained, hope it helps, Pete
    https://www.manualslib.com/manual/10...page=53#manual
    TT: Pro-ject 1.2, Ortofon Blue
    Phono stage: Muffsy
    Cd: Linn Karik
    Dac: Denafrips Ares II
    Amps: Pre: EleKit TU-8500, Power: Cambridge Audio Azur 651W
    Speakers: Chario Hiper Tower 2000
    Cables: Linn, Straight Wire & Chord Clearways
    Headphones:PC, Ifi Zen Air, Sennheiser HD450 & HD569
    Quote Originally Posted by Pete812 View Post
    Ta for the reply Peter, yes I think you're rite, managed to get a response from novatron in Korea so I've kind of sorted it, not sure I could be arst editing loads of albums but I've no doubt it would make the x40 more pleasurable to use
    I'm Peter.
    It'll give you something to do whilst you are listening to music
    Phono stage: Muffsy
    Cd: Linn Karik
    I'm Tony.
    The X40 is early model from NF and like all streamers of the generation has it's quirks (6 years and older), Pauld on this forum has owned one for a few years and I am sure he can ease you through the indosyncratic nature and pass on a few tips for you.
    Support is Via Novatron for these older models now
    Coherent Systems
    Real high end sound with musicality not hifi
    Quote Originally Posted by Mr. C View Post
    Thanks Tony
