Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: What is the weakest component?
    I'm Ian.
    Test your own hearing via the link below. With good quality headsets i found it to be pretty accurate.
    I'm Ian.
    worth noting that as with any medical hearing test it doesn't cover the full frequency range of hearing (or, technically at least, music).
    ''The frequencies (or pitches) that have been used during your hearing test are shown on the horizontal axis (the vertical lines). These frequencies are low on the left side of the audiogram (250Hz), then gradually climb to higher frequencies on the right side (8000 Hz or 8kHz). Humans hear frequencies from 20 Hz up to 20,000 Hz, but an audiogram only shows a subset of our hearing range: it focuses on the frequencies that are the most important for a clear understanding of speech (the spoken words)''.
    *Audiolab 6000CDT* Soncoz SGD-1 * Nelson Pass DCB1 * Krell KSA50s * JM Lab Electra 926 *
    I'm Ian.
    I'm Ian.
    How far do you need to increase the volume to hear each higher tone.
    If you can get up to 10 KHz you're pretty much good for anything music-related. Cymbals just about push 10kHz.
