Im replacing damaged bearings on a Technics 1200-1210 turntable. the problem i am having is the replacement MR2ZZ doesnt quite fit in the hole.
im looking to get a 150mm digital caliper to measuring the hole where the bearing should fit and get another bearing from somewhere.
not sure how to go about this tbh as i may need a custom bearing?
the other option would be to make the hole bigger somehow.
