Source
SW1X USB II
SW1X DAC III Special
Audiolab 6000 CDT transport
Amps
Speakers
BK Electronics XLS400FF Sub.
Cabling
Headphones
There are some very good bits of kit out there that do not cost thousands which really hold there own, this is particularly true in the digital domain, just need to know what to go for.
I hope it surprises you.
Read about this when researching buying my own.
It was the same few people who were posting on different forums about it, all around the same time.
My takeaway was that it was a "Friday Afternoon" job, a bad batch that affected a few folk.
Cant fault playback on mine, built like a tank, smooth and whisper quiet.
Zero scratched discs or skips, played every CDR and CDRW I've put in it.
AC POWER
AMPS
SPEAKERS
Wharfedale Evo 4.4
DAC
TURNTABLE
PHONOSTAGE
DIGITAL
MUSIC PLAYBACK
Ipad Roon Remote.
SPEAKER CABLES
INTERCONNECTS
Source
SW1X USB II
Amps
Speakers
Cabling
Headphones
Source
SW1X USB II
Amps
Speakers
Cabling
Headphones
You got to give them a good look at you jib if you want money off these days. I thought everyone knew that?
They’d probably charge me more.
