Have any one here given much time, thought and listened to the differences you get from using the different cartridge alignment geometry’s, I am think of the Baerwald and Lofgren alignment techniques. Is there a preference for one or the other, or is it a case of one is more suited to vinyl manufactured from a specific era. I personally have setup cartridges with both but to be honest never really sat down and seriously considered the advantages or otherwise.
I think the most satisfying sound was when I used a Graham Phantom and the alignment jig that comes with the arm lets you set up either of the geometry’s but also allows a mid point between the two to be set.
Look forward to peoples thoughts and actual experiences, it might just tempt me into giving it some serious though to actually trying the Baerwald and Lofgren setup’s and try to differentiate between the two.
A bit of an anal question but could be worth some careful though.
Andy - SDDW
