Page 2 of 6 FirstFirst 1234 ... LastLast
Results 11 to 20 of 57
Thread: Fuses ( I’ve never tried them for sq improvement)
    Woukd the results have been better if hifi tuning fuses were fitted in tbe test equipment?
    Now there’s a point
    'Fuses'... Wot be those, then?
    The best fuse is no fuse.
    Marco [hard-wired and proud]
    Surely there must be fuses in your audio equipment?
    Would the results have been better if hifi tuning fuses were fitted in the test equipment?
    A sensitive micro-ohm meter will be battery powered to eliminate mains noise. My Sullivan Type 666 Micro-Ohm Meter uses dry cells, and can measure resistances as low as a few micro- Ohms.
    I'm Adam.
    I though you were onto something so I took all the fuses out of my equipment.
    Doesn’t bloody work now. I think you may be a charlatan.
    Lol... Yes, but only in the equipment itself, not the plugs powering it - and mostly they don't exist
    i always use proper equipment as it was made. i figure they knew more than me
    The fuses examined in the test report covered all types, not just those that fit into 13A mains plugs.
    Quote Originally Posted by Beobloke View Post
    Put them back in, but the other way around. Now play a Country and Western record: your girlfriend will walk back in through the door and the dog will come back to life.
    Default Fuses ( I’ve never tried them for sq improvement)
    That’s my theory too Grant
    Wossat all about, then? Obviously a reference to something I don't recognise...
