Have you checked if there is an internal fuse (glass with chrome end caps) and if so has it blown? Would be a simple case of swapping like for like (check engraved writing on ends) if it's blown and then PA section will work aswell.
Sent from my I3312 using Tapatalk
Money may not make me happy.
But it helps me afford the kind of misery I prefer.
SYSTEM 1:
Analogue.
Brinkmann Bardo / 12" OL Enterprise Mk4 / Koetsu Rosewood Signature Platinum /BigBottle mk3 /MFA Baby Reference Pre/Nord One UP SE NC500M/Martin Logan Summit
Digital.
Docet Lector CDP-7TL mkiii/Pimped Bluesound Node2 + BOTW SBooster Lps/ Pimped Mk1 Jolida Fx Glass DAC.
Wires etc.
Audioplan Musicable ICs & TQ Black ll SC, assorted branded kettle leads.
Target TT shelf & Alphason 5 shelf rack.
Power Inspired AG1500S mains regen.
SYSTEM 2: Back to the 80s.
Garrard 401, RB250, A&R P77Mg / Mk1 Marantz CD63 SE / Sony TC-FX150 / Sansui T500L / Cambridge Audio C50 + 2x A50 as bridged monos (mid 80s Stan Curtis's design) / or KEF 104ab/ Original 80s Monster Cable IC, DNM SC / Target 5 shelf rack.
SPARE KIT:
A&R E77Mg
Ortofon 2M Silver + Blue stylus
Philips CD600
Arcam Alpha 8P
Pro-Ject DacBox S FL
CCA
FiiO Taishan
Heybrook HB1 S2
Q Acoustics 3050
