Unstable operating system.
I'm matt.
Makes you wonder how many speakers out there have been recapped and sound worse for it.
I was wondering if they've already been recapped by a previous owner hence your findings, but it's hard to get a definitive image of the original boards online, they might have been recapped before selling.
Incidentally, I found this video a wife made of her husband restoring their 104/2s. She says she really enjoyed the learning experience of soldering the second board herself. I must have word with my wife...
https://youtu.be/uAMvCsyZFaY
All the caps are original Kef marked caps and I can tell that all solder is original. My information came from an ex Kef engineer , it is a pain though that he has advised to not take notice of the marked values as it’s now impossible to know their original values albeit -/+ 2 % . Getting 2% caps now isn’t easy .
I'm charles.
Hi Andrew, there is merit in replacing caps that are, in your case about 25 to 30 years old, with modern ones even if the original are still within spec. New caps do sound better and today there are lot more to choose from.
Consider that most speakers are built to a price point to be competitive in the market so understandably lower cost options are used. Perhaps 2000 pairs of a certain speaker are to be built and it uses 6 caps/pair at a cost of 6 pounds. To upgrade to some that cost say 40 pounds means an outlay of an extra 68000 pounds! Will probably not go down well with the accountant.
Try replacing just the caps in the tweeter circuit and while you're at it the attenuating resistors as well. The white sand cast jobs are nasty and replacing these with Mills will contribute to the improvement. I mention the tweeter because it usually has the lower value caps in circuit and therefore cheaper as an experiment.
You also get to slightly adjust the result regarding choice of cap. A Mundorf EVO in Oil is great value. It has a very slight tilt up in the extreme high frequency, or a neutral and smooth Clarity Cap CSA. I found the CSA to nicely reduce some sibilance while still remaining detailed. I mention Mundorf and Clarity Cap because I know them well but there are dozens to select from.
As you are only upgrading the tweeters on one pair of speakers it will not hurt your piggy bank too much and you will then hear for yourself what all the fuss is about.
https://www.hificollective.co.uk/catalog/-c-61_68_what all the fuss is abou429.html
Personally, the resistors are the last things I would change.
If you really do have the urge to fiddle, then I agree that the component to experiment with are the capacitors in the tweeter circuit. These are directly in the signal path and so are likely to have a bigger effect than those in the midrange or bass circuits.
If it was me, though, I’d still leave them alone and enjoy them.
