Remote Sensor on DAB Radio
The remote sensor on my Pure Digital radio seems to have a fault. It will not pick-up a signal from the remote. I got the radio 2nd hand without a remote so bought a custom made remote form a Czech supplier recommended by a member. I've done the tests the supplier suggested to check if the sensor is working, and it appears that it isn't. Does anyone know if this can be repaired?
Linn Axis tt/Akito arm/Nagaoka MP200 or ATVM95/ML carts/Trichord Dino mk3 phono stage/dedicated PSU
Marantz CD6006/Cambridge 650T DAB
Tisbury Mini Passive II pre/Roksan K3 Dac/Roksan K2 integrated used as power amp
Atlas Element Integra Superior inter-connects
Spendor SP1s(1988)/Van-Damme UP-LCOFC HiFi 4mm cable
