Results 1 to 10 of 12
Thread: Power amp suggestions
    I'm Richard.
    Default Power amp suggestions
    Evening folks. Due to a change of circumstances I'm going to be selling my Graaf GM20 monoblocks.
    I'm looking at the various options to replace them.
    My pre is a SJS Arcadia 2 & my speakers Living Voice OBX-RW's so massive power not required.
    I'm looking at the 2nd hand market with an approx budget of £2K but the less the better of course.
    Probably looking at solid state. Valves not ruled out but I'd want lowish heat & self/easy biaising.
    Any thoughts?
    I'm Richard.
    I too have LV speakers. At present I have a WD valve amp driving them...excellent. But I also find a DADA-modded Quad 306 to be excellent too!
    If I wanted an integrated amp I'd be looking at the new Exposure 2510.
    R
    I'm Simon.
    There are some Canary 300b monos at Emporium for under 2k atm
    Kevin has had Canary for a number of years.
    SJS Arcadia Line Level Pre-amplifiers, Headphone amps, MM Phono Stages and SET Power amps - service, repairs, upgrades.
    Designed and hand-built in England.
    I'm Richard.
    Quote Originally Posted by sjs View Post
    Thanks Simon, hope you're well my friend.
    I assume that as the creator of my pre ..... they would be a good match then?
    I did buy an early canary integrated (608 I think) from Kevin many years ago.... Built like a tank, bloody enormous
    I'm Gary.
    Strong recommend for a Meridian 557.
    Enough clean current and grunt to power a small town, 1.6KVa transformer, dual mono circuit, delivers over 30 amps.
    Meridian Data-sheet:
    https://www.meridian-audio.com/media...-datasheet.pdf
    Pick up one for well under your budget, add another £800 or so for full service and recap by ex Meridian engineer still working on them and you’ve an amp for life.
    Love mine, subterranean power, absolutely neutral and wide open sounding.
    Will pick up a second at some point and biamp.
    New speakers first though.
    Its a beast, and as good as majority of folks would need imo.
    Drives anything even down to 2 ohms.
    Alan Sircom’s great review from back in the day.
    https://www.meridian-audio.info/publ...)%5B459%5D.pdf
    AC POWER
    AMPS
    SPEAKERS
    Wharfedale Evo 4.4
    DAC
    TURNTABLE
    PHONOSTAGE
    DIGITAL
    MUSIC PLAYBACK
    Ipad Roon Remote.
    SPEAKER CABLES
    INTERCONNECTS
    I'm Pete.
    Being a Meridian fan myself I agree with Gary - although if you get the chance to pick up a 2nd user G57 for under £2k go for it.
    Quad 909 is no slouch. Oodles of velvety power for the money!
    I'm Simon.
    Quote Originally Posted by Johnny nocash View Post
    Emporium also have a Canary CA301 mk2 which also be a good match but with more power, if a little over budget
    As Kevin has had Canary amps for some years I would expect them to be a good match with your LV speakers and I know the preamp should be fine with them.
    As for SS I would probably suggest Sugden. There are a couple of power amps on eBay atm and a few customers hare happy with their SJS / Sugden combinations
    Neurochrome 286 build (as you don't need the power of the 686). Could easily be done for under 2k.
    Having said that, if you get the gain structure correct with the pre-amp etc, a high power amplifier into sensitive speakers can be spectacularly dynamic. Although my 686 into 112db is beyond overkill to be honest!
    Quad Artera Stereo and money left over. Great sound, great build, drives anything and proper backup if ever needed.
