Results 1 to 10 of 15
Thread: Timestep fitting instructions
    I'm gerald.
    Default Timestep fitting instructions
    I have a Timestep that I have passed on to someone but I cant find the instructions .I have tried the search function but the threads i have found does not show any images any help would be great I have emailed them direct but no reply so far .
    Cheers Gerry
    I'm Kevin.
    Timestep what?
    Kevin
    I'm gerald.
    Sorry Timestep power supply
    I'm Kevin.
    Get in touch with Time-Step/Sound HiFi and they may post the instructions out to you.
    Failing that, a search on here will probably give you all the information you need, as I remember that there was a discussion about where you connected the negative feed.
    Kevin
    I'm gerald.
    I have tried Timestep spoke someone called Dave.He was much help as as chocolate tea pot .He refused to supply a copy of instructions .
    Quote Originally Posted by diviy View Post
    He owns Timestep. Did you try and grease his palms....
    PRE
    I'm gerald.
    That Dave guy was totally up his own arse .
    I have found some threads but pics are missing.
    It's a sore subject on here. He's been banned. I had a timestep PSU for my 1210 years ago, nowhere near as good as the Paul Hynes PSU I own.
    PRE
    I'm Kevin.
    There are pictures around on the web.
    Just bear in mind that it is general,opinion that the negative is in the wrong place if you follow the Timestep instructions.
    Google “fitting SL1200 PSU” and you should find all you need.
    Kevin
    I'm Ian.
    To be honest i found the instructions lacking and pictures could of been better. There is plenty of information both on here in the archives and web but you will need to go back in time. I believe the creator is no longer welcome and i agree can be a tad testy to deal with. If you are stuck i am willing to copy my set and forward to you. Ian.
