Had a wee visitor today that managed to push the wee circular dome at the center of one of my woofers.
Is there a way to pull it back out.
Was thinking duck tape?
Any solutions would be much appreciated!!!
I'm tony.
selotape first. if not strong enough try duck.. much depends on material and how bad it is tho.. heard of folk using a hoover but im not so sure on that
I'm tony.
Thanks Grant....its pushed all the way in.
Not the end of the world-very much a first world problem!!!
If tape won't do it you could push a thin needle through the centre then rotate/pull/wiggle it out.
Then seal the hole with a tiny spot of glue.
I've used a Hoover, but with a toilet/kitchen roll attached to the end of the pipe as it's gentler. If the Hoover had power settings remember to start on low!
If you go for the needle option there are some dental picks that allow you to "go round corners" and would help.
Sent from my BKL-L09 using Tapatalk
I'm tony.
sellotape worked a treat.....majik!!!
Magic Tape?
Good stuff.
I'm tony.
Sticky situation....
