Results 1 to 10 of 19
Thread: Sansui SP-1200a
    Default Sansui SP-1200a
    Some 1976 Sansui’s that I just picked up locally, the guy bought them new in Dubai in 1976, he clearly took care them.
    I haven’t listened to them yet and I’m not expecting anything more than average.
    You might be surprised by those.
    I best at least try them then in that case .
    amazing condition for the age.
    yes they are capable speakers and work best fairly loud i think
    92db sensitivity, won't need much power to get high levels from them. Designed back when watts were expensive. Quite like Kabuki speakers myself, they have their foibles but what design of speaker doesn't?
    Need to be close to a wall to get some bass response out of them although that's a plus for many rooms where sticking the speaker out in the open is just not possible.
    These are definitely not to be laughed at guys , I’ve hooked them up to my Quad vena and they are bloody good speakers, they went a bit fuzzy for a minute so I’m guessing the caps needed charging or something but they’re singing away now
    New monacor caps ordered.
    I'm Barrington.
    Sent from my VOG-L29 using Tapatalk
    If they had a "fuzzy" moment, it could well be dirty pots on the level controls. Work them back and forth a bit, that may clean them up enough for now. You can use contact cleaner too, just be careful with it as it can dissolve some plastics.
