I'm Simon.
Thanks. One thing I have noticed is that the start of he records are always the worst. I cleaned them in the disco antistat and my guess is that is where all the fluid/removed dust resettled as its the last place to dry out. Its the vacuum thats missing isn't it - think i will buy a pro-ject machine.
Precisely, muchacho, and I said as much earlier!
Good luck with the Pro-ject. I'm sure it'll be great, and if so, be prepared to hear (or rather not) your records like never before!
Now all you need to consider is which cleaning fluid to use, or whether to make up your own for a fraction of the price... And I can advise on both if necessary
As an alternitive i've found that the ultrasonic cleaning tanks work realy well, Spider who's a member here and the Audio Abattoir makes them.
I'm Simon.
I've just sent the Degritter at a mere £2499...
I'm Simon.
Seen...
GrahamS - It's not what you hear that counts, it's what you think you hear........
Present Kit: NAD 326BEE, NAD C515BEE CD player, JVC QL-7 DD turntable, JVC Tonearm, Shure M97Ve, Audio Technica AT95EX, Pickering V15, JVC Z1E, Wharfedale Diamond 230s, Visual Rio interconnects and My Ears.
