Page 1 of 7 123 ... LastLast
Results 1 to 10 of 67
Thread: Snap, crackle and pop...
    I'm Simon.
    Default Snap, crackle and pop...
    That's the annoying sound of vinyl through my new Rega RP6 Exact cartridge and Elex R amp. I have only had the system three months but am ready to give up on vinyl. I have carbon brush, Milty stat gun and have clean records. I started my return to hifi 3 months ago committed to vinyl but find myself playing my pimped node 2i nearly all the time now. I have just bought Cairn, the jazz album by Fergus McCreadie which is amazing but the start is so noisy it's just really disappointing. Any ideas, I just don't remember vinyl bugging me so much before with my old lp12 and quad system.
    New vinyl doesn't seem to be as clean straight out of the wrapper as it used to be, i find even new un-played LP's need 15 minutes in my ultrasonic RCM before they hit the deck, so my advice is buy an RCM even a manual one like the Knosti Disco Antistat will give you good results
    Hi Simon,
    Welcome to AoS and nice to see you contributing
    The simple answer to achieving 'quiet vinyl' is to invest in an RCM - and bugger the cost! Perhaps by spending less on the T/T itself, cartridge or arm. It's really the only way
    I can tell you from considerable experience that, for example, a good quality, but cheaper cartridge, playing *pristine* vinyl, properly cleaned on an RCM, will sound MUCH better than a more expensive cartridge playing records that are less clean (or dirty), as Mike makes a good point about even new vinyl these days not being genuinely clean (in terms of the inner grooves, where tiny particles of dust and dirt can gather during the production and packing process, which on playback is then 'seen' by the stylus).
    The fact is, it's piss-easy to CLEAN records - simply running them under the tap will make dirty records appear cleaner - but it's what happens afterwards with the dirt that's removed, and where it ends up! All you're really achieving is loosening it and moving it somewhere else...
    That's why RCMs are *so* effective, as that dirt is instead sucked up with a vacuum.. And you simply can't get records properly clean (or anything approaching silent during playback) any other way.
    Plus, the other thing that RCMs achieve so well, is in removing STATIC build up from records, so once clean and properly stored (inside anti-static sleeves), thereafter become fairly impervious to attracting dust or dirt, and pristine clean records also drastically increase the life of your stylus!
    So all in all, if you're truly serious about hearing vinyl at its best, and have a decent sized record collection, then the ownership of an RCM is a *MUST*, and so simply cannot be seen just as an 'optional accessory'.
    ^^ wat he said
    I'm Simon.
    Thanks for the replies and for moving it, I wasn't sure if it fit here.
    I do have a disco antistatic and cleaned that new lp before playing. It still pops and crackles and I think I can differentiate what is the occasional dust particle that may cause a mistracking for a few rpm vs. the more constant static noise that incidentally seems to build throughout playback. I am going to check if everything is earthed today first. I don't want to throw the towel in yet and am not short of money so might buy an RCM. Maybe i can hear someone's system who has one when the COVIDS over. Thanks.
    Quote Originally Posted by BultyBoy View Post
    Sorry, Simon, those are dreadful things, only fit for the bin. You need something like this (chosen based on your available budget): https://thevinylfactory.com/features...l-connossieur/
    And as I said, static build up will become virtually a non-issue with the use of an RCM (and crucially the RIGHT fluid), and also good record-handling hygiene and storage habits.
    The other thing, aside from that, to ensure that noise is reduced on playback, is in ensuring *optimal* set up of your cartridge and arm, and the cartridge especially in terms of azimuth, as any misalignment there will accentuate distortion and noise - plus also choose a cartridge that doesn't inherently accentuate groove noise, which some 'posh' fine-line MCs are prone to doing!
    Out of interest, as I haven't read any of your previous posts, what T/T, arm and cartridge are you using?
    I'm Simon.
    Ok, its the same as the knotting disco antistatic quoted earlier i think but other than looking nice it doesn't seem to do much. I have a Rega RP6 RB330 arm and Exact cartridge at 40 hours probably.
    He is using a Rega P6 with Exact cartridge. The correct geometry is set by the third fixing screw in the headshell and the height of the cartridge designed for Rega arms.
    Rega cartridges are relatively unfussy when it comes to record imperfections and dust etc, part of their philosophy for trouble free listening.
    I'd try the problem records on a different turntable first. if acceptable i'd be taking my rega back and demoing my issue to the retailer, and asking for a cartridge or stylus swap. stylus would probably do it
    certainly in advance of making up my mind to spend 400 500 1000+ on a vacuum based cleaner
    why?
    i have a cheap stylus cockeyed in its mounting which when carefully aligned will track anything. even if it has groove damage
    i have a more expensive para trace for the same cartridge which is nosier and falls foul of the invisible but audible issue the previous stylus tracks.
    its great and worth the money to get it fitted...... in all aspects but this.
    every stylus even of the same design runs a slightly different path, if you have one at one end or the other of a pretty small manufacturing tolerance in respect to cut or in the rubber suspension it may not perform as well as it might. maybe it was made late Friday afternoon after a pub lunch
    my comparison is an elliptical with a paratrace which isn't quite fair
    but either way
    checking there is nothing wrong with the business end of the player would be my first port of call before investing a considerable amount in a cleaner that may not help in the way you need it to, at this point in your analysis.
    still a handy thing to have but you buy one to clean records and we don't know if yours, really need a good clean
    Dave
    I have found to my cost in the past but a stylus that gets into the bottom of the groove will give you
    more snap crackle and pop, I have found that for less snap crackle pop run an eliptical stylus.
    That applies to clean records as well.
    Turntable : Project 2 Xperience Tone Arm & Cartridge : Project 9c Ortofon 2M Blue Phono Stage : Project Phono Box SE II Digital Source :Primare CD21 Integrated Amp : Primare I30 Speakers : ProAc 110 Headphones : Beyerdynamic DT770 Pro
    Revox A77 MK IV 2 track 15 & 7 1/2 IPS
    TEAC A-3300SX 4 track 7 1/2 & 3 3/4 IPS
    Akai 4000DS MkII
