These seem to start in price at around £8.00 on that very well known site.
Anyone with experience of such-like....at the cheaper end please??
.....looking for something that works without breaking the piggy-bank!!
I'm Kev.
Have and used one of these for ages.
https://www.ebay.co.uk/itm/Digital-L...0AAOSwyd1gOnkb
Turntable : Project 2 Xperience Tone Arm & Cartridge : Project 9c Ortofon 2M Blue Phono Stage : Project Phono Box SE II Digital Source :Primare CD21 Integrated Amp : Primare I30 Speakers : ProAc 110 Headphones : Beyerdynamic DT770 Pro
Revox A77 MK IV 2 track 15 & 7 1/2 IPS
TEAC A-3300SX 4 track 7 1/2 & 3 3/4 IPS
Akai 4000DS MkII
I'm Kev.
Akai 4000DS MkII
Turntable: Sony TTS-8000 ;Tonearm: Phonomac AT-1010 Mk6; Cartridges: SPU GTE / VDH Colibri XGP / Decca SC4E rebuilt by ESCO with Paratrace; Phono Stage: Shindo; SUT: Bob's Device Cinemag 1131; Pre Amp: Shindo Monbrison; Power Amp: Shindo WE 300B Limited; Speakers: Shindo Lafite / Auditorium23 Solovox; CD Player: EastSound CD-E5 / Sony PS1; Cables: Yannis 423.5; Yannis 223.5; VDH The First Ultimate; Totem Sinew; Audio Tekne ARSP-500 / Auditorium 23.
Lumley Heliosphere Audiomods 5
Hovland HP200 MC
Hovland Radia
Ming Da 805 monos
Magnum Dynalab Etude, RWA Cassabria + LCD 3
Wilson Benesch Actors
I'm Graham.
https://www.ebay.com/itm/324338023127
I had the one mentioned in above posts but had problems with the batteries flattening and faint display.
This unit is better with a regular AAA battery and the screw on attachment means the cart is measured at the correct height which does makes a slight difference to the reading. Only disadvantage is the bigger size and the attachment is fiddly to fit so is best left on at all times.
I'm Matt.
I’ve got both the ones linked to above.
The one with the side attachment measures down to .001’s, where as the one on the first link “only” measure down to .01’s.
Both seem pretty accurate comparing to each other & another gauge I also have.
The one with the side attachment is a bit more fiddly to use & store. The first one seems ( I’m sure it actually IS) exactly the same as the one branded as Pro-Ject & a few other names as well.
Either will do a great job & are good enough for the keen amateur.
I'm Kev.
Thanks for all the info.!
Think I'll be happy enough measuring to 0.01g...so will go with the scale referred to in post #2
You may well find, especially with the cheap Chinese-made scales, that the magnet of a moving coil cartridge will give a false reading.
Sent by me using an appendage
SME Model 15/V tonearm, Lyra Dorian, EAR Phono Box.
Luxman 509X amp.
PMC 25 23i speakers.
Innuos/Roon/Qobuz/I-Pad. Oppo UDP-205.
Cables by Kimber, Yannis and Audioquest.
Audioquest Niagara. Tube Distinctions Mains power filter. Project RCM. Zerostat.
