Selling this great little half width Power Amp. The Precision 3 by Audio GD.
They're a China brand doing wonderful things in the HiFi world (just Google them) and this little amp is one of their best.
I have it on good authority that this design is 'inspired' by Bakoon but around a tenth of the cost.....
Below is taken from their website:
Fully discrete design, Non- feedback, current mode ACSS and DC coupled analogue power amplifier
The gain stages and pre-buffer stages all work in class A, built with discrete analogue stages without any opamp or coupling capacitors in the signal channels.
Diamond Cross Non-feedback output stages designed to avoid "switch distortion", rivaling class A amps.
2 analogue inputs: RCA and proprietary ACSS single ended
In total 4 transistors (150W / 15A each). Supports 70W X2 (8 Ohms) output power and 13W X2 (40 ohm headphone)
Power Supply capacity of more than 40,000 uF, powered by oversized transformers
Built with high quality precision 0.1% KOA resistors and WIMA capacitors.
To guarantee cleanest sound and avoid electromagnetic radiation internal metal shielding panels are installed
Further information can be found here:
http://www.audio-gd.com/Pro/amp/Prec...ecision3EN.htm
Comes complete with original packaging and power cable.
Looking for £330 delivered to UK mainland addresses only.
