Page 1 of 4 123 ... LastLast
Results 1 to 10 of 35
Thread: Anyone else’s Roon being an ar5e?
    I'm Russell.
    Default Anyone else’s Roon being an ar5e?
    Getting a bit cheesed off with Roon since the 1.8 update.
    From time to time it won’t find certain Audio Zones so I have to restart the core which is a PITA as I run it headless.
    The zones are showing in settings as enabled but you can’t select them to play to as not showing there. Even disabling them and then enabling them again doesn’t resolve the issue.
    It’s not specific zones that are the issue either, it’s random. One day it will be the core that it can’t find, other days it’s an endpoint I use wirelessly so it’s as if it’s an issue with an endpoint, it’s definitely with Roon.
    Anyone else experiencing this or know a fix?
    I'm Peter.
    Quote Originally Posted by Weeman1973 View Post
    I’m afraid I can’t offer a fix but I’m experiencing the very same issue since the 1.8 update. However, it’s only with endpoints temporarily disappearing and as yet the core has been stable (NUC).
    At the moment, it’s more of an irritation than a disaster and looking on the Roon forum, others are experiencing the same problem.
    Let’s hope the technical team get this fixed sooner rather than later.
    not had that issue so far. hopefully roon will find the problem soon. I did have an issue similar which was when core and the endpoint i used to update was finished the other endpoint was unreachable as it hadnt been updated. hence it was still on 1.7 and couldnt run. I had to uninstall that endpoint program and reinstall at 1.8,
    It could be something like that i guess.
    I'm Peter.
    Had a similar issue with the Microsoft Surface, it wouldn’t update to 1.8 and was stuck on version 1.7.
    Had to deinstall, and reinstall 1.8 Manually. (No such issues with the NUC / IPad or Android Phone).
    To be honest, I thought it was just Microsoft being their usual self and making life difficult
    I'm Gary.
    All good here,
    only running 2 zones if that makes a difference.
    Core installed on AP Linux to Roon Endpoint.
    AC POWER
    AMPS
    SPEAKERS
    Wharfedale Evo 4.4
    DAC
    TURNTABLE
    PHONOSTAGE
    DIGITAL
    MUSIC PLAYBACK
    Ipad Roon Remote.
    SPEAKER CABLES
    INTERCONNECTS
    Quote Originally Posted by Boyse6748 View Post
    The issue was when, from the pc i was on and instructed to update all, i forgot that the program(not the core server) wasnt powered on, on the core machine although the server was.(its a laptop too) so it couldnt update it. whe of course you try to then run 1.7 with a 1.8 core its incompatable. there was a info panel that came up but couldnt be read as the roon grey box covered it. so took me a while to work out what had happened
    I'm Gary.
    Ah ha...
    AC POWER
    AMPS
    SPEAKERS
    Wharfedale Evo 4.4
    DAC
    TURNTABLE
    PHONOSTAGE
    DIGITAL
    MUSIC PLAYBACK
    Ipad Roon Remote.
    SPEAKER CABLES
    INTERCONNECTS
    I'm Edward.
    I've been getting this as well. Most annoying. Always have to restart Core.
    A RPi running Ropieee is the end point. It is seen within Roon Audio settings but does not show up as a zone until Core is restarted.
    This issue only seen in the mornings - I tend to leave Core and the RPi endpoint on 24/7.
    Prior to 1.8 everything was rock solid. Core running on a win10 machine (headless, I restart via RDP).
    Do either of you have a link in the Roon Community where this issue is being discussed please?
    I'm Peter.
    Quote Originally Posted by Edward View Post
    Yes ( Link Below) you have to log in or Register
    https://community.roonlabs.com/
    I'm Edward.
    Hi Peter,
    Sorry I should have been clearer. An actual thread where this specific issue is being discussed. I'm already registered in Community.
    Cheers
    Edward
