Originally Posted by
Nigel
One of those ifi itube2 valve buffers might be exactly what you are looking for. They can be used as a single input pre amp as well, assuming swapping cables is no hardship, access wise. I'm sure you could pick up a used example and sell it on for not much loss, if it didn't produce the required results.
getting a decent valve amp on your budget is a bit challenging , i would go with nigels suggestion . you could get an arcam c31 for your budget as well , while not valve its VERY good for the money
https://pinkfishmedia.net/forum/thre...lifier.251108/
Eric Bibb
