I've decided to install a small RPi solution in the bedroom for occasional use.
I have a lovely, currently unused, pair of Kef Coda 7 that are small enough that I should get away with it!!
I'm after a steer from all the RPi experts here who helped me get started last year. As always I'd like to spend the least possible to achieve acceptable sound, given it'll have light use and lowish volume.
I wondered about getting an RPi 4 and swapping that into my main lounge unit, then reusing the 3B+ in the bedroom. But is that worth it, will the Rpi4 "upgrade" what I currently get with the 3B+?
If not there's RPi 3A units around at under £30, would this be OK with an added Just Book DigiAmp HAT?
Are there other (cheaper?) DigiAmp options?
I'll mainly use to stream radio or Tidal HiFi into the Kefs.
I'd like to keep things neat, so a simple RPi unit makes sense I think, rather than attempt to get a small integrated amp past SWMBO.
Any guidance appreciated and if anyone has anything suitable they'd like to move on please drop me a note.
Sent from my motorola one using Tapatalk
