I'd guess setting the Oppo to max output from min output gives an increase in dynamic range aka 'bit depth' - higher signal to noise ratio, hence more audible detail and so forth.
Regards
Brian
Amplifier : Sony TA FB740R
Speakers : Tannoy 637
We don't know what volume the Oppo was set to before though. If it was set at full output previously and clipping the pre-amp, which as you say can happen, it would have sounded pretty poor.
Assuming it doesn't clip the pre-amp the optimal thing to do is have the Oppo at full output and adjust volume on the pre-amp. That way you know you are getting the full dynamic range. But then that means no remote control of volume.
[QUOTE=brian2957;1252652]There you go David
Cheers Brian, I'll take the time to look through this over the next couple of days.
Mark Levinson 390S CD / Audiolab 6000 CD / Croft 25RS Special Preamp / Croft 7R mono Amps / Neat Ultimatum XLS Speakers
You've got it Lawrence. Croft Pre fixed at 7 O'Clock, and Oppo CD volume anywhere between 15 and 75, which rocked the Kasbah
Hahaha...love it David
Gary ( gazjam ) is the man for Oppo mods .
Regards
Brian
Right I'm with you now.
Lots of Oppo 95 mods here http://tweakaudio.com/EVS-2/Oppo_95_mods.html
