see title
see title
Yannis, I think.
https://www.shop.back-promo.co.uk/
Main system: Sony TTS8000; AT1010; Audio Technica Art1; The Lentek; Cambridge 851n, Yamaha NS1000.
System 2 - SBT; Technics SH-X1000 DAC; Denon PMA-850
I'm guy.
Yannis Tome - lovely chap, very helpful and excellent products at reasonable cost (at least, I assume he is the chap you are looking for)
edit - great minds and all that
LP12, Ittok (black), DV10X5, NVA Phono 2 (twin supply), NVAP50, Art Audio Quintet 15w power amp, NVA LS5 cable, Rega Ela mk1's.
Sony CDP XB930.
I think the 'Youfannis' guys are on another Forum
Yannis that's it! Been wracking my brain for the past 30 mins for that!
Emm, well thought I needed a phono cable with earth lead, but I;ve just connected my 1200gr with its original tonearm with a standard phono - both ends - and its fine, no buzz whatsoever, is there any point in buying one of these?
https://www.shop.back-promo.co.uk/Mo..._17485525.aspx
Well only you can answer that!
Who knows? But I'd still spend £40 at Tesco on a decent bottle of whiskey. £40 is nothing to spend on a tonearm cable, it probably costs something similar in parts and postage. Why not take a punt and then report back.
The new Technics turntables are self-grounded via the mains plug, you don't really need an earth lead if you're using the stock tonearm which is grounded to the chassis.
