im not sure re pcm wav.. i think it is flac at 96khz
These are the formats supported:
FLAC (up to 96kHz/24-bit)
HE-AAC
LC-AAC
MP3
Opus
Vorbis
WAV (LPCM)
WebM
Taken from here - https://developers.google.com/cast/d...a#audio_codecs
Kevin
Thanks Kevin.
I've seen that. I suppose, because they don't explicitly state that wave files are supported at 96KHz, it means they are not.
But if the internal DAC can convert them, why can't it transport them also?
I just don't recall having the problem before the weekend and I've been using the thing for years.
Johnny Dodgem.
Cartridges vintage MMs including Pickering xsv-4000/xsv-3000 : Stanton 881s/D81 : AT140LC/VMN40ML
Spinners hot rod 1210 (Jelco 750D, Origami, Ammonite, Longdog, Vantage, Achromats) : Pye G63 & Garrard AT6 : Two full custom Lencos : Kenwood KD-650D
Streaming Qobuz : BluOS & Node2 (Fidelity Audio modified) : RME ADI-2 DAC
Pre-amps Tron Seven (GT modified) : Conrad Johnson EV1 : Croft Micro 25 : Decware ZStage
Power Amps PrimaLuna ProLogue 5 (KT120) : PrimaLuna ProLogue 4 (KT77)
Speakers The Edingdale : Meadowlark Hot Rod Shearwater
What changed at the weekend?
Kevin
It seems you are not the first to experience this. https://pinkfishmedia.net/forum/thre...ster-2.248565/
Kevin
I changed many things at the weekend; power amp, DAC and cables.
You can see why I thought that the cable is the most likely culprit.
It may still be part of the problem. However...
I've have just put my Bushmaster TC-7530 DAC alongside my Rega unit and compared them.
The Bushmaster will play the 96kHz files via optical. The Rega will not play them via either of its two toslink inputs.
The Rega is specified to convert such files.
I'll try it with another cable when the postman delivers.
Otherwise, any ideas what is upsetting the Rega DAC?
Thank you.
What Rega DAC is it?
Kevin
It's the original. Launched in 2011, if I remember accurately.
Johnny Dodgem.
Do you have a different source that you can feed the Rega DAC at the sample rate you want?
It may be an incompatibility between the CCA and the REGA DAC. There seems to be a few reports of that happening on the Web.
Kevin
Good idea.
I have a Squeezebox Touch in the workshop. I'll fire up the Logitech Server for the first time in years and feed the Rega from that at 96kHz, as a comparison.
I'll report back.
