Hello.
Has anyone encountered problems with QED optical cable in the 'graphite' range - not carrying data at 96kHz?
I have toslink to mini-toslink termination.
Thanks.
Hello.
Thanks.
Johnny Dodgem.
Cartridges vintage MMs including Pickering xsv-4000/xsv-3000 : Stanton 881s/D81 : AT140LC/VMN40ML
Spinners hot rod 1210 (Jelco 750D, Origami, Ammonite, Longdog, Vantage, Achromats) : Pye G63 & Garrard AT6 : Two full custom Lencos : Kenwood KD-650D
Streaming Qobuz : BluOS & Node2 (Fidelity Audio modified) : RME ADI-2 DAC
Pre-amps Tron Seven (GT modified) : Conrad Johnson EV1 : Croft Micro 25 : Decware ZStage
Power Amps PrimaLuna ProLogue 5 (KT120) : PrimaLuna ProLogue 4 (KT77)
Speakers The Edingdale : Meadowlark Hot Rod Shearwater
I'm Jo.
That's my understanding also, Joanna.
However, when I send 96kHz files to my DAC via this cable, I'm getting nothing but distortion. It's working correctly at sample rates below this, at both 16 and 24 bit resolution.
Odd.
Johnny Dodgem.
I'm Jo.
What is the set up you are using this in?
Kevin
This is in my workshop system.
Qobuz Hi-Res > Wireless 2.4GHz > Chromecast Audio dongle > QED 'Graphite' optical cable > Rega DAC
i) I've ordered a cheap optical cable to test against the QED and determine if it's the interconnect.
ii) I thought Chromecast Audio was capable of acting as a transport for 24/96 PCM wav files. Perhaps it can only transport the FLAC codec at this resolution.
Does anyone know?
The internal DAC of the Chromecast can translate these streams - but I don't want to use the Chromecast convertor.
Perhaps I'll post in the digital section about that, if I don't get a response in this part of the forum.
I'm fairly confident my
Chromecast Audio > Beresford Bushmaster
didn't have this problem, and I know the Rega is happy with 24/96, hence I suspected the cable (or damage to it).
have you selected hi rez in the system options for chromecast... im sure you used to have to select hi quality...
There is no option to change audio settings other than dynamic range or equalisation, using Google Home.
I have the second generation of CCA.
You have turned on full dynamic range?
Other options are to try a different cable, and if that does not change anything, send it back for replacement.
Kevin
Yep, full dynamic range is on.
I've been using it for years. This problem is new, which is why I thought the cable was prime suspect.
Johnny Dodgem.
