Can anyone recommend some Bluetooth Earbuds to be used with an iphone, I am look for bang for bucks.
Cambridge Audio Melomonia
Kevin
I'm Andy.
I use Enacfire G20's and they are superb - I am on my second pair as my lad borrowed my first pair (he used Apple Air pods) and he wouldn't give them back
Main system:
Analogue.
Network Player.
Digital.
Philips DCC 730 player
Marantz CD50SE
Amp.
Audiolab 8000A
Speakers.
Reiver Jenna floor standers
HeadPhones.
The Enacfire are more in my budget, those Melomonia are a bit pricey!
Pricey, but good.
Kevin
I use Mifo 05 and they are pretty good.
Bernie.
Another vote for the Melomanias, sound great and quite simple to set up. They also have a very good battery life and the carry case holds a charge if needed.
Turntable
CD
Network Player
Cambridge NP30
Amplifier
Speakers
Cables
Headphones
Thanks for all the recommendations chaps.
If you're prepared to go second hand I was planning to sell one of my 3(!) pairs of Flares Pro earphones. I've not used any of them much as I switched between them regularly. Some great reviews online.
They can be used wired too if required as they have an external balanced dac/amp that clips on to a collar/shirt. I was thinking £90 posted.
Sent from my BKL-L09 using Tapatalk
