Wiring from tonearm base to tag strip in plinth!!
As it says....I'm wiring from tonearm base to tag strip in plinth!!
It's a Mission 774...and on a Heybrook TT2
I've rewired wand with Cu Litz wire....and want to avoid mechanical effect of hanging 'thick/heavy' cable (as came with the old 774 ) from underside of the arm base....so going 1st to a tag strip inside plinth.
Suppose I could use more litz.....but thinking of a 'pseudo balanced' approach using a thin 2-core screened cable....one cable per channel.
Heard that Van Damme XKE might be suitable....but which one exactly??
Perhaps there are better alternatives?
I'll be buying only 1m.....
- You may not post replies
- You may not edit your posts
Forum Rules
