Won't be needing this anymore guys.
Works a treat and cleans 3 albums at a time.
£250 delivered.
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
❶2 industrial grade ultrasonic transducers(2×55W=100W). High performance of ultrasonic transmission. Higher than similar products in industry. 2 ceramic heaters(2×80W=240W), with optimized power regulation for special cleaning and laboratory applications. 6 L capacity tank for professional cleaning.
❷35KHz Strengthened transducer makes the ultrasonic powerful yet gentle clean and won't damage your valuables while keeping them looks like new.Ultrasonic vibration can quickly and thoroughlyremove minimal dirt from the surface of the object.
❸Timing function 0-30minutes for 6 timer setting(5/10/15/20/25/30mins). Heating function 122℉-140℉ for 5 preset temperature 104℉(40℃)/ 113℉(45℃)/ 122℉(50℃)/131℉(55℃)/140℉(60℃).3-color LED display, Degas.
❹DURABLE & DOUBLE SECURITIES - Built-in 2 cooling fan one for cooling PCB,one for ultrasonic transducer to help cooling cleaner during working, which can extend the lifespan twice longer than mechanical ultrasonic cleaner. This ultrasonic cleaning machine is equipped with a double cut-off power outlet for safe use. Isolated-Circuit design,good capability of waterproof.
