Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: Roon Remote App Continually Losing Connection To Core....
    I'm Peter.
    when you lose connection to the core click on the 'need help' link on the middle of the cannot connect screen and enter this as the ip address of the Core - 255.255.255.255
    That might help, it did for me years ago when I used Roon ( ditched it for Logitech Media Server/Material Skin instead )
    use these instructions:
    On a remote like a phone or tablet running Android or iOS, when you try and login and cannot connect there will be a screen that shows up and you should see a line which says “Make sure your Roon core is powered on and connected to your network.”
    Below that line there is a blue “Help” link. Click that “Help” link and you will have a pop up which allows you to enter the IP of your Roon Core.
    That is where you enter
    255.255.255.255
    This will need to be done on each remote that has a connection issue.
    Thanks MikeyB
    I thought I was a bit of Roon expert, as I’ve been using Roon without problem since it was first introduced.
    However, I have always been iPhone / iPad (apple) man for remote control together with Roon Sever on a NUC. “ Never an Issue”.
    I have now (after 10 years of apple) changed to Android, Which was originally working fine but last night for the first time ever.... Lost Connection and wouldn’t reconnect.
    Anyway, to cut a long story short, the 255.255.255.255, which I completely forgot about..... instantly reconnected the Android phone.
    Many thanks for the reminder..... I must be getting senile
    Quote Originally Posted by Boyse6748 View Post
    Thanks MikeyB
    That's great, I had to dig deep into my whatchamacallit? lol to remember even part of the number sequence, what I find strange is that is such a common problem that it's not easier to find the solution on the Roon Forums.
    Anyway, I'm an LMS man should we even be talking lol
    I'm AMusicFanNotAnAudiophile.
    The 255.255.255.255 number is a subnet on the network.
    Your devices are commonly on 255.255.255.0
    It looks like you can't control Roon locally (ie without an internet connection).
    Chris
    Common sense isn't anymore!
    it does need an internet connection, but you can go offline for up to 30 days i believe.. the licence gets checked every 30 days.
