Some suggestions.
Log into your router and increase the DHCP Lease time to a longer period. I've set mine to 10 days.
Within your router change the IP address for your iPhone and you iPad to fixed or not fixed (basically toggle the settings).
On your iPhone and iPad got to wifi settings and 'Forget' your network and then rejoin to it again (obvs you need the wifi password for this)
Change 'sleep' setting on your iPhone and iPad to a longer period.
Disable any VPN you may be using on your iPhone and iPad.
Disable WiFi assist on your iPhone and iPad if enabled.
Reboot your router.
Good luck.
Reason: addition
