Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: Atkinson SOTA TL
    I'm Rob.
    when I removed a B110 to explore the cabinet fitting (in view of replacement), then listened without it - the fatiguing aspect disappeared
    You could try an L-Pad which would enable you to have the B110 at any level...or off
    https://youtu.be/ZCBe7-6rw4M
    If the crossover capacitors are tired the filter slopes could be all over the place, best sort that first. Then play with phase and see what that does. And as mentioned, adjust levels if need be.
    I'm Kaleb.
    Thanks for all the input.
    Wilmslow recommend a Monacor unit to upgrade a B110.
    It was a bit of an anxious router job modifying the cabinet, but the one I've swapped so far sounds great. Once my local audio electrical engineers reopens after lockdown I'll ask them about the crossovers.
    Thanks all
    K
Tags for this Thread
