I built a two tier plinth for a 401, 30mm solid oak. Lower plinth supported on sorbothane and the smaller upper plinth with the chassis mounted, coupled to the lower with spikes into flat discs with indents to locate it. Arm pod mounted onto lower plinth. Spikes couple but the mass is almost doubled by the two levels.
My Denon DP80 has a different looking plinth on the same two tier principle on spikes.
I'm Song.
I
Separate arm pod . Can be troublesome to level armpod if your Tonearm tower for VTA adjustment is too tight. I have a Thomas Schick TA on a Reed armpod . Every time I adjust the VTA , my alignment will get shifted
I'm Song.
Separate Reed arm pod with Thomas Schick Tonearm . VTA adjustment tower is too tight . Everytime I adjust VTA , alignment will shift .
