Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Thread: Budget high compliance cart for SME 3009s2 improved?
    I'm Neds.
    Default Budget high compliance cart for SME 3009s2 improved?
    As above. Posted this on the Wam a few months ago. There seems to be very limited choice for this particular version of the 3009. I originally had an AT 110e on it, which I seem to remember working fine, until I bent the cantilever. I wondered if the new AT 95 VM range would work? Or indeed, any other modern carts? It’s got a Pickering V15 on it at the moment, but with a stylus of unknown age/ hours. It plays ok, but can be sibilant, which suggests some wear
    I'm Pavel.
    Hi Neds, is your tonearm S2 improved (with detachable headshell) or Series II Improved (non-detachable headshell)? The former's effective mass is 9.5g which makes it compatible with many of today's cartridges including AT-VM95, Ortofon 2M series etc.
    I'm Neds.
    It's the detachable headshell version, which I think means it's the lightest?
    I'm Pavel.
    I don't think so, the headshell socket adds quite a bit of mass. The non-detachable version is 6.5g — now THAT is problematic. S2 Improved (9.5g) is fine with many of today's cartridges including even some MCs (e.g. Goldring Eroica).
    I'm Neds.
    You've opened up my world! The gist from elsewhere on the web was that a high compliance cartridge would be best, which aren't manufactured in such great numbers/ varieties. The Pickering sounded good when I was using the Audiolab as an integrated, but when I used it as a phono preamp, coming out of the tape sockets, it sounded very muffled?
    not had an issue using carts with the sme 2 imp. just add extra weight to the back weight. itll do 2 grams or so tracking easily too. ive used loads of carts with mine, when i had one.
    Pavel is correct. Your SME is the 3009 Series II (Improved) S2, with a detachable headshell. Assuming you will use the arm with the SME headshell the effective mass is 9.5g.
    It is not possible to quote a preferred cartridge compliance to suit the arm, as you need to take the mass of the cartridge into account as well. Without actually suggesting a particular cartridge, ideally any cartridge that satisfies the following will be OK:
    175 < MC < 400
    where M is the total mass in gram (= effective mass of the arm (9.5g for your arm) + mass of the cartridge + mass of fixings (say 0.5g)) and C is the compliance (in compliance units (e.g. 6.5 for the Audio Technica AT95)).
    Information for other cartridges can be found on the vinylengine.com cartridge database.
    I use an SME Series III which is lighter than your arm and it has worked well with Ortofon 2M series and the latest AT VM95 ML. The AT's are a real bargain and suprised me how good they sound.
    GyroDec 2M Black, Amplification: Luxman 505ux.
    Loudspeakers: Harbeth HL-K6
    Quad 99 CD, Amplifier: Teac A H 500i, Loudspeakers: SCM11
    Receiver: Teac CR H500, Loudspeakers: B&W CDM 1NT
    I'm Neds.
    This is all very useful. I can’t understand how I was sent down a high compliance blind alley! All the carts that you’re now talking about are the ones that I was considering before that distraction. Thanks all and a Happier New Year 😉
    There's nothing to stop you adding a bit of mass to the headshell if it helps. Suitable weights are available.
