I fail to read anything negative about the KSA 100, aside from the weight of course - but who’d buy one to use as a portable headphone amp?
So, tell me about your Krell. Why on earth should I buy one?
Thanks!
Thanks!
Ben Duncan mains conditioner
Samsung QE75Q90T 75" QLED TV
Atacama SE24 stands
I have an agreed sale of one from a member of this parish, though I can’t pick it up yet for obvious reasons. Been doing a fair bit of research and there does appear to be little criticism about. I plan on going through the amp and recapping it, should be good for another 30 years then.
Hunter S Thompson
great build quality so dont see why not if looked after.. can only go up in value too
Visiting civilians will think you are insane.
On the negative side they weigh a ton.
On the positive side any burglars will probably put it straight back down if they try to lift it and just look for your phone, laptop and car keys.
Sent from my BKL-L09 using Tapatalk
I'm Allen.
My opinion is and will allways be " If it's heavy it's Good "
Made from huge transformers ,heat sink's ,Caps etc
This is mine on the inside:
Nice. I love the heatsinks on the capacitors and inside the fan cowls; that's attention to detail.
Atacama SE24 stands
That's a mark 2 so the fans blow upwards, not down as in the mark 1. Puts out 650 watts of heat through the top vents so also functions as a fan heater.
On the really hot days in summer I had to swap it out of the system as it was just too much.
I still think the later 'S' series are better amplifiers, from a strictly hi-fi angle, but that's a minority view amongst the Krell cognoscenti. Much harder to find a 'S' in Europe though.
I'm neil.
Is this a different model ?
I was just looking to see if there were any for sale
http://
